Funny thermostat problem
Frank Cheng
Member Posts: 22
I encountered 3 Honeywell thermostats that had the same funny problem. The thermostats would heat themselves up and cause turn-off in about 1 - 2 minutes after turn-on. It seems that the heat was caused by the mercury contact in the bulb and the heat cause the temperature sensing coil to expand like a rise in the room temperature. They are all round simple type of thermostat of 1-3 years old. I don't know how to fix them. I replaced them all with regutangular ones and got rid of the problem.
Does anyone have the same problem and know what is going on with this products?
Were the anticipators
in the round stats set to match the thermostat current of the relay or valve being operated?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Heat anticipators?
Honeywell T87 thermostats have heat anticipators. These are small resistance heaters located behind the sensing element that begin to heat up when the stat calls for heat. They artificially heat the sensing element so that the thermostat loses its call before the room heats all the way up to set point. That way, the residual heat in the boiler/furnace will heat the space just up to the setpoint, not drive it past setpoint which would happen if the stat lost its call when the room hit setpoint.
Okay so far?
Well the anticipator is settable. You are supposed to set it for the amp draw of the control circuit. Set it too high and the room overshoots the set temperature. Set it too low and it undershoots.
I bet the heat anticipator was set too low.0 -
I will check the current.
Thanks for the input.
Frank0 -
I think that must be the answer. Most of my heating is forced water system with outdoor reset control which almost eliminates overheating totally. So, I am going to simply set every one of them to the maximum or near that neighborhood.
Frank0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
