heat loss ques.
Tom_53
Member Posts: 43
heat loss
Can i use a hydronic heat loss to size a furnace?
Thank you, From Jack.0 -
a BTU
is a BTU, Jack..if we are talking about conventional Manual J heat loss, then the answer is yes. If A/C is involved, then the latent gain would need to be adressed and an appropriate blower CFM/ firing rate relationship established. Rarely, if ever, will you find the cooling load the same as the heating load.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
