Wet heads are THERMODYNAMIC (bigugh)
Gary Fereday
Member Posts: 427
A quotation of Dan's is that "even a mistake in heating will awared you a small victory." or words to that effect.
Now below, this is a significant statement and points to Dan's revelation.
Thermodynamics is a fancy subject. The first time you go through it, you do not understand at all. The second you go through it, you think you understand it, except for one or two small points. The third you go through it, you know you do not understand it, but by that time you are so used to it, it does not bother you any more.
Arnold Sommerfield
I do not know who Mr. Sommerfield is, or his qualifications, however I understand his idea of thermodynamics.
Here is a site that you could explore to find out a lot of information on the subject of wet, wetheads. IMHO bigugh
http://www.ifigure.com/
Arnold Sommerfield
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 78 Chimneys & Flues
- 94 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 377 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 41 Industry Classes
