Priming/Painting Radiators
Diane
Member Posts: 1
I am in the process of preparing a room for re-painting. The house is approximately 48 years old...so the radiators are NOT 'antique.' The hot-water low-profile radiator will have to be stripped of years of paint. What is the best prime to use, if recommended...notice there is a grey prime on the radiator now. Also, can I use a flat latex paint on the radiator as a finish coat? Posted 01/20/03.
renewing radiators
I replaced all my old convectors with cast iron radiators around two years ago. Found twelve radiators with years of paint, etc... I found someone to sandblast them, which got all the paint and any rust, then I had them powder coated, which comes in many colors, we used gold. The coating provides a durable and long lasting finish. Cost was $70-90 each depending on the size. If you can remove the radiator, it may be worth it to find a metal shop to help you out.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 993 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
