Who makes the most quiet power vent HWH
Brian (Tankless) Wood
Member Posts: 222
to the Takagi's and put your ear to the unit, to hear the quiet purring sound they make. The motor is inside the unit, not on top, bolted to the flue.
240 gph minimum (up to 400gph) and they hang on the wall. Very space-saving, and they NEVER run out of hot water.
Please call for Brian for pricing: (337) 430 4649 (Louisiana).
I'll attach a pic, and send more info if you wish. See all details at www.takagi-usa.com four models available with energy factors of 0.82 to 0.84. No tanks come even close!
Happy heating
Brian.
Happy heating
Brian.
Quiet power vent hot water heater
I need to replace a 50 gallon water heater with a power vent model. It's in a finished basement so I want something that's as quiet as possible. Suggestions?0 -
How far
will you need to run the vent pipe?
If you are next to the wall that the vent will terminate, you may want to consider the Bradford-White direct vent. It is sealed combustion and prices out about the same as a power vent.
Cut and paste this link: http://www.bradfordwhite.com/products.asp?category=Residential_Gas_Water_Heaters&id=7
Mark H
It's in the middle of the basement. Up 2-3 feet, one 90 degree elbow and then a straight shot 13 feet to the wall.0 -
i installed a state power vent
75 gallon today, and was astounded at how loud it was...manufacturers take note...loud-no good.0 -
DV not pV
Try rinnaina.com. On demand. Cannot buy on internet. Must be bought and installed by a factory certified plumbing contractor.0 -
I recently installed a Polaris HWH... In all of my years of heating I have never found a more quiet peice of heating equipment.0
