Ques. on Buderus 2107 Prim/Sec design
Rick Price
Member Posts: 9
I have a system to install using Buderus 2107 control. Normaly, I use Taco/Tekmar controls - but this owner is looking for a top to bottom Buderus system. My questions are: How to control the primary pump (off the Taco circ. relay end switch??) and if I do switch on the primary circ. this way will it cause the 2107 to go nuts. I know there is a constant circ zone available on the control, normaly controlled by a Room sensor - but I don't think this would be effective for the primary cicuit. Anyone tried a similar setup with the 2107 ??
The Buderus web site has a PDF file of application notes which show how to set up the 2107 with various designs and external controls. Go to http://www.buderus.net and click on the "Literature" topic on the left. Then look for the "Applications Manual Ecomatic and Logomatic Controls".
I suggest you download and print the document rather than viewing it directly in your browser.0 -
Terminals 61 & 63
Terminals 61(N) and 63(H) are 120-vac powered outputs for space heating pump(s). I understand this power is interrupted only for DHW priority, condensate protection, or WWSD. With this power source, you can start or interrup the primary pump through end switches and a pump relay. The 2107 Logomatic control will maintain boiler temperature based on a selected heating curve. This is the best I can offer without knowing more about your system. Hope this helps. Ken0 -
thanks guys....
the answers were right in front of me ... but they say that's the best place to hide things!:-)0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 993 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
