freezing pipes
Troy_3
Member Posts: 479
Sorry to take so long to reply. The pap on this job feeds Slant-fin BB. The homeowner installed a wood burning fireplace so he hasn't used his first floor bb zone. Second floor is running great. The basement has a drywalled garage with no heat. Surprise,surprise first floor froze somewhere. Good news is- with suplimental heat in the garage it thawed out last night and started to circulate. Glycol is going in tomorrow. I usually try to talk customers out of glycol unless there is a strong reason.
freezing pipes
hiya gang how you all keeping today,as winter is getting mighty cold burst pipes etc come to mind,well here is my silly question for the day,as i have for many years seen a copper pipe split when frozen,can pex be used instead,will it split in such cold conditions as copper does.
many thanks
all the best
gary usa0 -
freezing pipes
With this cold snap a new dilemma. I'm for the first time trying to thaw pex and pap pipes. My pipe thawer in no longer a help. Any advise? I even thought of tring to attach to the aluminum inside the PAP. Seems a little risky though.0 -
Luck and patience
The best results I've had with frozen floor tubing has been to lay a covered loop on top, hook into the boiler circuit and feed full temp water - can take a few hours but is non invasive. For freezeups exposed or accessible - an electric melt cable or two. Looks like another cold week ahead - pile on the blankets..... Dan
How are these pipes freezing. Are they exposed or is it cold enough to freeze because of not having slab edge insulation.
Was the system shut down? How long did it take to freeze.
I am trying to get some idea of what I should expect if the power went out or a circulator shut down on my slab edge which isn't insulated.0 -
Ken
I would hope that some sort of freeze protectant was used in your system.
While even an unisulated slab will take some time to freeze, it can happen.
Talk to your heating contractor to see if this has been done.
Mark H
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
