how to calculate EDR for rad's for a DIY
steve_6
Member Posts: 243
go to www.burnham.com/tools.cfm and click on sizing obsolete radiation
I think my boiler maybe undersized I want to figure my rad's to see if it was sized right. Is there a easy formula?I know I must get the name of the rad, but are they mostly similar in construction. I think my boiler has a EDR of about 450-490.
Thank You Jim0 -
Thank You Jim0 -
EDR
Thank You Jim0 -
EDR
Thank You Jim0 -
You need to measure
the radiators height and we would need to know whether they are column or tube type.
The depth of the radiator would also be needed.
Once we know what style and size you have we can calculate the EDR. Then we would multiply that number by 240 to get to the steam btu's.
If you give us a description of the rads we can help you figure this out.
Mark H
Web sources for EDR
How many times are you going to post the same question?
There are charts in "The Lost Art of Steam Heating" book here. A couple of web sources are http://www.colonialsupply.com/resources/radiator.htm (tube vs. column illustration farther down 2nd page reversed) or http://www.antiqueplumbingandradiators.com/askpage.html0 -
Web sources for EDR
There are charts in "The Lost Art of Steam Heating" book here. A couple of web sources are http://www.colonialsupply.com/resources/radiator.htm (tube vs. column illustration farther down 2nd page is reversed) or http://www.antiqueplumbingandradiators.com/askpage.html0 -
Web sources for EDR
You must have a decent size home if 450-490 EDR is not enough. My boiler is rated 283 sq ft and radiators are only about 158 sq ft. (3 bdrm 2-story), so my boiler is oversize.0 -
Web sources for EDR
You accidently reposted several times.
My boiler is rated 283 sq ft and radiators are only about 158 sq ft. (3 bdrm 2-story circa 1910 in N.IL), so my boiler is oversize.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
