boiler water content
steve_6
Member Posts: 243
I'm in the process of replacing an old coal converted to natural gas steam boiler vintage 1910. Its a vapor system with millivolt controls, 500 sq. ft. of radiation and a gravity return. I would like to keep this system as simple it is now. No condensate return pump. Do I need a boiler with a larger water content to do this and can you still get them with millivolt controls? What boilers would you recommend? Thanks
Water Content
isn't usually a problem if the system is set up properly. On a Vapor system you need to keep the pressure low- if the system doesn't have a Return Trap or Differential Loop, a 0-16 ounce Vaporstat is a must. If the pressure is kept low, the boiler won't have to generate as much steam and consequently use more water.
I haven't seen a gas boiler offered with millivolt controls for quite some time. But check with your supplier- they may be able to order one.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
