Glycol & Hard water
John G. Merritt
Member Posts: 140
Guys,
Is it a fact that Glycol and hard water (from well)
is corrosive to Hydronic (radiant) systems and affects the circulators,Zone valves, Heat exchangeer, etc?
What if there is a water softener, does it matter?
John
John
Yes, it's possible.
If you click on Hot Tech Topics on the big pipe at the left of the main screen, about nine topics down is a good discussion on antifreeze. They talk about water quality, too.0 -
Yes, it's possible.
If you click on Hot Tech Topics on the big pipe at the left of the main screen, about nine topics down is a good discussion on antifreeze. It takes you to http://www.paloma@raypak.com/afreeze.htm
Starting with a clean system and usin distilled, de-ionized water is the way to go. It's mildly corrosive, but it gets neutral pretty fast, especially if there's iron in your system.0
- 86.4K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 926 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
