CO Detectors
Richard Rascati
Member Posts: 4
Can anyone recommend a good CO detector for general home use?
Richard Rascati
Richard Rascati
CO Detector
Our is a C8600A1000. Battery powered, low battery warning, self tests every 10 minutes. Visit www.honeywell.com/your home/ for more info if you are a homeowner, see your distributor if you are a contractor. Thanks!0 -
CO Monotors
National Comfort Institute sells a low level monitor that sounds the alarm at 10ppm. First Alert and Nighthawk go off at 70ppm after measuring for 4 hours, we call them death alarms.We sell only to contractors. www.ncinstitute.com0 -
Check out CO Experts
Carbon Monoxide Low Level tester.
George Kerr is who you contact, check website:
WWW.coexperts.com
This is probably the same unit National Comfort Institute is selling.0 -
Pricing
Is there a list price, etc. on that website? Couldn't locate.
Bill0 -
No price you have
to get in touch with George or Comfort Institute for pricing.0 -
co detectors
> general home use?
> Thanks Richard Rascati
co detectors
Be careful of what you buy. Follow the instructions on where to or not to install them and do the maintainance on them. Don't be suprised if your tempted to throw the thing out the window after the first few false alarms. These units have long history of this, especially First Alert. Then we run into the problem not paying attention to something that cry's wolf to many times!! good luck0 -
CO Experts is an a low level alarm that prevents injury to all members of the family where store alarms only protect adults. Because of their low level intial alarm (10ppm) it is recommend that it is purchased from a local contractor well trained in CO investigations. Most false alarms are the fault of the investigator not the alarm. These alarms are not sold direct to homeowners. National Comfort Institute can give you the name of a dealer in your area.
1-800-633-70580
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
