Steam Pressure
Joe_5
Member Posts: 19
I always "crank it down" on all of the residential steam jobs I'm on. Never had a complaint afterward. My question, does a large steam system need more pressure, say like a medium sized elementary school? The boiler attendant keeps his system cycling around 6 psi. The classes are hot on one side of the building and the other side they're wearing jackets. Each room has a puematic tstat which operates a zone valve but they don't seem to control the system so well. I'm just a parent on this job and not the contractor. Any thoughts on what could be wrong? Thanks guys! Joe
If you can heat part of the building I would say the boiler output pressure is Ok.
In most of the US the controls systems are fell safe to heat. If you turn off the air compressor the side of the building that is cold should stat heating. If for some reason there is still no heat I would start looking at the system piping.
Closed valve maybe. But I would say that the pnuematic system needs a calibration.0 -
In most of the US the controls systems are fell safe to heat. If you turn off the air compressor for the controls and let the system pressure go to 0 psi the side of the building that is cold should stat heating or you can turn each room thermostat up to 90 you had hear the air bled off and the room should start heating. If for some reason there is still no heat I would start looking at the system piping.
Just remember to turn the air compressor back on after the test or you may cook the gold fish.0 -
Steam Pressure
I guess it could also be a loss of air pressure to the one side of the school if those zone valves fail open. Thanks for the idea. Joe0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
