burner identification
Jim_47
Member Posts: 244
Can anyone help me identify this burner? Is brand new and was in the storage part of the warehouse. Its amazing what a snowy day has us digging out. The only marking is the model number DM30. It has a webster 2 stage pump. and it is marked 2.25 - 3.00 gph. Oh it also has dual nozzles!
as another hint; It has a fan/limit switch wired to it as well as a fan rly so it must have come from a furnace.
thanks
thanks
Guessing from the color ,
I will say to try contacting DMO (duomatic-olsen), and give them any numbers you can find . 2 stage pump is for either long run or high lift situation , so maybe a horizontal ceiling hung unit ? I believe they still make this type of burner , but I've never seen the twin nozzles . Aero uses a similar chassis , maybe the'll have some insight . Keep us informed . Chris0 -
I think it's a Ducane
my parents' Lennox furnasty has a Ducane that looks like yours.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Good call Steamhead !
That's the one I couldn't think of .0 -
Burner ID
I agree it looks like a Ducane. Be forewarned if you try to call Ducane you get a big time runaround.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
