rule of thumb
Chris Janowski
Member Posts: 9
Are there any rules of thumb for figuring out how many btus you can get out of fin type cast iron radiators at 180deg water temps?
( eg: Area of fin x number of fins?)
I have a 1500 sq ft house, built in 1918 and would like to use these radiators to keep in line with its vintage. Heat calc show that I need about 40,000btu/hr.
Any wisdom, or wise words of advice would be much appreciated.
Frog
Frog
At Books and More
on the pipe on the left, order and get EDR to find out your intended radiation output!0 -
Otherwise plug off the openings and submerge in a
vessel of water and calculate through the displacemant, The area of the radiator. Each Sq. ft. of area will deliver 240 btu per hour with 1 psi steam, & 179 btu per hour with 180*F hot water bigugh0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
