burner cycle timing on a vapor system
Eddie Cutts_2
Member Posts: 5
Thanks to "Steamhead" and Dan's forum here our system is running quiet and warm. Now to fine tune!
Presently our burner is running on average for a 5 minute 45 second cycle every 16 minutes. The pressutrol is set to cut in at 1/2 psi and the differential is set to 1 pound. The anticipator on the thermostat is set to .2 ( Honeywell ). I also have some bad radiator traps. Will the bad traps if failed in an open position allow the boiler steam pressure to bleed off through the dry returns and cause the pressurtrol to kick in and make more steam pressure?? Or is our problem more in the present control settings?? Should we leave the settings alone and change all the traps then note the difference?
That's what I'd do, Eddie
then you only have to adjust it (if needed) once!
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
