009 wiring diagram what connects to what ?
Chris Burt
Member Posts: 19
Is the white wire(nuetral) and the yellow (line)the pump is working but it is vibrating my copper tubing. Never had that problem with the 007 pump. Installed the arrows so they are pointing the same direction. Is it ok to mount the pump with the motor horizontal? What else could be causing the vibration?
out on a limb
very different pump curves, you're pumping toward the point of no pressure change instead of away, and what you're hearing/feeling are symptoms of cavitation at the pump inlet?
What prompted you to replace the 007 with an 009?
Mark0 -
A second story addition with another 400 feet of pipe.0 -
I would have left the 007 in place it would have worked.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
