recommendations and suppliers needed
Chris Hehman
Member Posts: 1
So, I bought a 75 year old house and spent the money and had all the nasty asbestos and the 75 year old boiler removed. The new boiler is great and I can work out in the basement without fear of sucking down the asbestos. So, now I need to re-insulate the 75 year old iron pipes (~2.25" OD main and ~1.312" OD leads and risers). I also need to replace many of the vent valves on the radiators. I am thinking of the clam-shell type fiberglass insulation and adjustable valves and possibly thermostatic radiator valves in the critical areas (ie., the baby's room). The problem is, I can't find any suppliers for the standard valves or the TRVs; anyone know where I can find an on-line catalog or a contact number so I can call for a catalog? Also, is there anything else that can handle the heat of the mains besides fiberglass?
Try two places.....
www.controlsdepot.com and www.statesupply.com; I have bought from both with good service.0 -
try high temp armaflex
http://www.armaflex.com/www/armacell/armacell.nsf/ansHTMLSeitenLookUp/US_Frame?OpenDocument
easier to work with...costs more than fiberglass but you "can work out in the basement without fear of sucking down the" fibers....0 -
Chris
Write to Tom at Tunstall for all of those type of valves. He visits the wall every once in a while.
(tp@tunstall-inc.com)
Noel0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
