CSST
Bill_3
Member Posts: 34
What is the meaning of CSST.
CSST
Corrugated Stainless Steel Tubing
It's the yellow plastic coated gas pipe that is purchased in large rolls and cut to fit. The connections on the ends are heavy brass compression type fittings.
Dale W.0 -
Spelling unsure
CSST is corrugated stainless steel tubing. Sort of a range connector on steroids, works fine in some applications.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 853 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
