Rigid 122 Pipe cutter
Wayco Wayne
Member Posts: 615
to my Rigid pipe cutting station. It has started spiraling up the tubing rather than cutting it. What do I adjust to correct this?? Thanks in advance
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
HOW ABOUT.....
Starting about a half-revolution, then going reverse for a spin in full, then forward till the cut catches the first groove that you need. if not wait till yo arm heals !!0 -
Clean and oil
the rollers and cutting wheel. That always works on mine. An old REED rep shared that with me years ago. I use WD-40 first to dissolve and clean the pins and inside the wheels, than some light oil, like those zoom oilers..
Dirty pipe or fluxed pipe "adjustments" will gum them up. Even a dull cutting wheel will give you some more miles after a clean & oil
hot rod
Hot Rod. Makes perfect sense.
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
