losing water
Bob Gagnon plumbing and heating
Member Posts: 1,373
in my area the average is about once a week. you probably have a packing leak or a leak on a steam vent. look around and fix it. you don't want to add more water than you need to. bob
water loss in boiler
I was just reading about someone that has a simular to mine. I have a 2 pipe system dry return but seem to be low on water probably twice a week is that the norm. I read what you told the one person about leak in the firing chamber or packing on valves. Should my or any system be sealed except for main air vents? Also should I insulate return lines? Main lines are as much as can be. Thank you, love this site very helpful.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
