Adding TRV's on 1 Pipe Steam system?
Greg G.
Member Posts: 1
In dan's book, The lost art of S.H. Page # 96 talks about adding TRV's to 1-Pipe Steam Systems. I looked @ a home this A.M. that has Steam Convectors, not Rads...
Is there any thing I should do different for Covectors that I would not do with Rad's?
You'll have a little pipe work to do
if you want the trv to be accessibile. Mad Dog
Couple of things
first, depends on your definition of convector, if it has aluminum fins on it, pitch will be critical, and you'll probably have condensate spitting out the vent along with water hammer after the installation of the 1 ps valve. Inlet valve and convector tubing would probably have to be at least 1 pipe size larger than normal. The aluminum fins "give up" heat faster than cast iron rads and don't hold the heat as well, ie, more condensate on each cycle. This is why Danfoss does not recommend the use of our 1 pipe steam valve on copper baseboard systems. If the convector is cast iron single pass, increase the pitch back to the inlet and maybe it will work.
also, if the convector is multipass, don't think I'd do it, do difficult to vent and drain.
Good luck
DWood0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
