hooking up radiant to a heat pump
Chris_4
Member Posts: 75
do you hook up radiant to a heat pump, or can it be done? anyone with information, your input and expertise is very welcome!
thanks
Chris
thanks
Chris
A good match if
you can work within their temperature limits. A buffer tank is a must! Most of the manufactures will have the sizing, piping, buffer, and control schematics available for you. Find a dealer that is willing to spend the time to assure a proper, and trouble free installations.
There are some important steps to be takenHappy heating!
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
Hot Rod, What is your feeling about the new
modulating/condensing boilers? Specifically, could they possibly eliminate the need for a buffer tank? Mike0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
