help low water cut off
paul_20
Member Posts: 4
Help...Thanks for getting back to me guys
Let me start over I have a Weil McLain SGO 6 Boiler a two pipeO-E Vapor lock system 13 radiators with no vents on them. 3 Radiators have replacement Valves on the supply pipe not vents. The returns on the system were replaced by a Hoffman #4a Steam main vent (replaced O-E air exhausters.) The system ran out off water in 26 days approximately. Where did the water go? Because or mineral build up Weil McLain says it is not good to fresh water feed the system or put a Auto water feeder on it. The old boiler HARDLY EVER NEEDED to have water added to it. How Can I test the system for leaks not the boiler? The air vents on the returns seem to release quite often. Should they vent often I never heard the old vent ever.
HELP SOS THANK YOU
HELP SOS THANK YOU
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
