pipe insulation- what kind for steam pipes
Ray_2
Member Posts: 21
I have a one pipe steam radiator setup in my house, the house heats uneven. It seems the 1st step in fixing this would be to insulate the pipes. What to you use? Armor flex (black foam tubes) looks like it would melt. Fiberblass pipe wrap, preformed fiberglass tubes? What is the right stuff.
fiberglass
One inch wall, and make sure the glue on it can take the heat. Look for a steam rating on it.
Zeston and Proto both make fitting covers to go with it.
http://www.hudsha.com/fiberglass.shtml
http://www.knauffiberglass.com/index.cfm?fuseaction=prd.dspProdDetail&ID=1
Noel0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 925 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
