Hotrod?
Earthfire
Member Posts: 543
What did you comeup with for stub and offset bending dimensions for that copper bender of yours?
Bending and swedging
Here is what I have come up with so far. Thinking about a copper/ transfer plate job.
The swedge tool make the bender all that much more versatile. Kinda hard to bend 20 feet of copper without a joint or two! The swedge tool makes "mistakes" fixable with only one solder joint.
I have found a couple bending software programs online. Looks like you enter all the points and dimensions and it gives you the index mark locations. That would help for multiple bends on one pipe. Maybe one day I could bend 20 feet of tube into something. I have some good towel bar ideas in mind. I need a little more practice, however, before I load some expensive stainless steel into 'er.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
Bending and sheetmetal fab software
at this link. Looks handy.
hot rod
http://www.merrymech.com/bendtech.htm
looks interesting
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 925 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
