Dual use water heater / hydronic install (PAH)
hot_rod
Member Posts: 25,443
Never said I didn't condone dual use, just that it must have a Flat Plate HX to isolate the fluids. Every time hot water is used in this home, a flow is generated through the Flat Plate HX too. When at rest, gravity circulation takes over on the potable side of the FP HX. No flow check.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=98&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
