Semi Instantaneous Compact water heater
keith
Member Posts: 224
Looking for Feed back on the Semi Instantaneous Hot water heaters. The one I am looking into is a Patterson- Kelley steam driven unit. Seems to be a no brainer. In my case I would get rid of 2500 gallon storage tank, with 1 steam coil and 1 condensate pre heat coil, the system is showing signs of fatigue. Any maintenance issues that I should be aware of with this different equipment? The system that is in the building now is nearly 40 years old and untill recently was worry free. Am I installing a service problem child? Any practicle experience or thoughts are welcome. Keith
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
