No Heat in Basement Radiator #2 (one-pipe system)
Neil Spiegel
Member Posts: 2
Same situation as in "No Heat in Basement Radiator #1".
Situation 2.
3 Story Home
Mixed 2 pipe and single pipe system (a bit wierd I know, a bunch of two pipe rads, then a bunch of mono-flo ts)
3 New rads in the basement.
1 works
2 don't
1st is right on the floor, it is connected to the two-pipe set-up
2nd is on a bench (bench footing, about 15" off the ground) it is connected off of one of the mono-flo set-ups. This one is really wierd. I'm attaching a schematic to show it.
To compound the problem the run is long and windy. I would say someting like 8 90s in and out.
Furthermore the Ts are only about 1.5 feet apart.
The upper floor rad gets heat. The lower does not.
MTs = Mono-flo Supply
MTr = Mono-flo Return
The basements aren't freezing (though it is only late Nov) but they are insulated, and they have lots of overhead pipes so I might not need peak efficency from the heating system, just need to get the rads that aren't working at all going.)
Is there a protocal to follow to try and solve this? Or do I put in electronic baseboards. <yuck>
Are there mini-inline circulators I can put just in front of the valve in the basement to reduce the resistance, and push some water through it?
Situation 2.
3 Story Home
1 works
2 don't
Neil, I ran into something similar
and the solution on that job will be to put the basement radiators on their own zone. We're going to use a Monoflo loop with two Monoflo fittings per radiator. There just wasn't enough pressure differential in the existing main to feed down to those basement rads.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
