difference between Heat Pumps?
Post by Don for Bert
Member Posts: 1
Can any one here help Bert out with the question below?
"Would you please explain the difference (if any) between a Residential Package Heat Pump with Gas Heat And a Split Heat Pump With Gas backup.
Also I would like the location of a dealer or distributor in Huntsville Al. "
Tip: Engineering ebooks on topics like pumps at
www.bin95.com/ebooks/
heatpumps
i think you might be better going to hvac-talk.com and asking your question good luck
I sent him here.
Figured our Southern gentlemen can help.Retired and loving it.0 -
Not much
That is as far as btu are concern.Now for installation reason the package can be a blessing no worry about not enough combustion air, drain lines and the problem that go with drain problem,no line sets and losses to worry about,not even a concern for stack pipe issue.However you are limited to crawl space installation on residental installed.That the only difference in a package and the split system.
Now if you are thinking warranty then the split system is a better deal.With most package equipment only gives a 10 year heat exchanger warranty and again you are limited to
80 afue efficiency on the gas side,and not many high cop
package out there either on the heat pump side.
One other thing come's to mind and the only people I know that made a dual fuel package unit was carrier,and I am not sure if they still do.
And keep in mind also wheather can really play havoc on outdoor equipment,thats why they only offer 10 year warranty
So if I was to offer the package unit it would not be for efficiency reason but more for the limitation of not being able to installed a split system.
If all possible go with a split,better warranty and more option as fars as efficiency and comfort is a concern.
Hope this helps0 -
dual fuel/ splits/package units
As a general rule the package units are not as efficiant
as a split system. If you want dual fuel,A nice condensing
gas furnace or better yet an oil furnace with a heat pump coil works great. Its as good as forced air gets.Carrier makes a super dual fuel stat.0 -
re; heat pumps
> efficiant as a split system. If you want dual
> fuel,A nice condensing gas furnace or better yet
- 84.4K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3.1K Oil Heating
- 57 Pipe Deterioration
- 801 Plumbing
- 5.5K Radiant Heating
- 372 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 81 Job Opportunities
- 22 Recall Announcements
