converting hot water back to a vapor system
steve_6
Member Posts: 243
> I have a Mouat two pipe vapor system that was converted to hotwater about
15 years ago. There were no changes made to the radiation, throttling valves
and steam traps are still in place. There were some small changes to the
near boiler piping that could be easily changed back. On cold days the house
does not stay warm. I've had a long and costly history of boiler problems
and another one has just come up. I'm considering replacing the boiler. My
question is this. Should I stay with the hotwater or convert back to steam.
> thank you,
> thank you,
return ells
If it still has the return ells on it, I'm not surprised that it heats poorly. The holes inside are very small.
If it doesn't have them, it will be expensive to convert back, because traps would need to be put on each radiator, in addition to any other things that have been changed around when it was converted.
I'd consider changing back, then examine EVERYTHING on the system before I decided to convert.
Noel0 -
If it never worked right after conversion
there may be other issues besides those return ells- such as too-small return piping, etc.
I'd seriously consider changing it back to its natural state- VAPOR!
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
