Two Digital Thermostats one TACO 009 Circulator
Chris Burt
Member Posts: 19
Can two thermostats be connected to one pump? I would like to connect them in Parrallel.
Yes, but
only if the thermostats are getting their power from the same circuit. The "R" terminals of the thermostats need to be connected together.
If in parallel, if EITHER of the thermostats call, the pump will run.
- 86.4K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 926 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
