Pipe won't budge.
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
If it's only a short piece of 1-1/4" pipe, just take your sawsall blade, put it in the pipe and make two opposing cuts through the pipe being careful not to cut the threads of the coupling. You've got to make sure that the blade stays parallel to the pipe to get an even cut.
After the cuts are made, the pieces should come out quite easily.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Pipe won't budge
Yup this is a 1 1/4 " black pipe thats been sawed short.
It is threaded into a reducing coupling that joins it to the main 2 " pipe. My problem is this: How can I heat the reducing coupleing to help free up the 1 1/4' pipe when the walls of the reducing coupling are practically 3/8" thick.
I have tried some penetrant sprays and a little heat...but I still cannot back off the 1 1/4" pipe from that heavy reducing coupling. If all else fails I may have to just get a welder in here to braze a nice little 1 1/4 " copper fitting on to the stub of the originally remaining 1 1/4" black pipe.0 -
Just like this -
Took a few pics on the last big steamer . When you knock the wedge out of the cut you make , you want to hit the leftover piece of pipe in a few spots to loosen it up .0 -
Took some pics -
of the last steam job , and cutting out the leftover pipe in a tee . When you knock out the wedge you cut , make sure to hit the leftover piece with a hammer in a few spots to loosen it in the fitting .0 -
stuck
another way...Change the reducer coupling...Use a large hammer to backup and hit the opposite side of the coupling with another hammer where it attaches to the 2" pipe ... Follow this procedure all around the coupling and unthread the loosened coupling... get a new reducer
al0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
