baseboard heat/new covers.
I am a woman in search of new covers for my base board heating system.
Where should I begin?? I am having no luck with searching the net. Am I using the wrong term?? I am only a carpenter's daughter so I don't know too much about HVAC.
Thank you
  • BB covers ?
    > board heating system. Where should I begin?? I
    > Thank you
  • BB covers ?
    Gennerally, you must get the same manufacture that did the BB in the first place. See if you can find a name anywhere on them. A good clear close up photo placed here on the wall may ID them for you. After that it is fairly easy! bigugh
  • Start with measuring them
    to identify which product you have. The back plate will be the best place to start.
    Then check different manufacturers products for a match. If you have Slant/Fin, you might start checking the Fineline 30 or 15. Here is a link to the sizes.
    http://www.slantfin.com/prod-fineline30.html
    http://www.slantfin.com/prod-fineline15.html
    http://www.slantfin.com/baseboard.html
    Noel
