Vacuum Problem
Vic P.
Member Posts: 1
I am a service technician for SEARS HVAC, after the installers installed a new steam boiler we now have 2 radiators that will not heat. I have not been on the job but the tech that is handling it has called me for advice.He tells me that if he removes the radiator vents that air sucks into the system apparently due to vacuum. He says he cannot find the main vents ( where I believe may be some of the problems ). Also the mains are not insulated. He has re piped the near piping and the boiler is made by Dunkirk and has no top boiler tappings. The system has 1 supply tap from the boiler front. Any advice is appreciated.
Thanks Vic P.
Thanks Vic P.
is the boiler
the correct size for the radiation? is there a sag in the piping leading to these radiators? is the new boilers pressure the same as the old boiler?sounds like steams condensing before getting to the radiator.0 -
vacumm problem
might seem like a dumb question did you install a steam boiler or mistakenly installed a hot water boiled all the staem boilers i have seen have had a 2 or 2 1/2 taping off the top?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
