Grooved Concrete - DF
Dana Zaichkin
Member Posts: 29
If I recall from your original post, wasn't this a really thick slab and the underfloor predominantly for tile warming?
Some projects I say I wish I never started, swear I'll never do again, but seem to anyway.
Wow
DZ
Wow
DZ
Here are some pics of the grooved concrete job I posted questions on several weeks ago. The architect dictated that there were to be no thresholds between the kitchen remodel, the addition and the existing home. Due to the thickness of the finish floor (marble) we had to groove the concrete to keep within the required floor thickness. A thin leveling mudset will be set over the piping and existing structural concrete slab before the marble is laid.
We grooved the concrete using a gas powered concrete saw to make two parallel cuts. We then chiseled out the groove with a rotary powered chisel. The only way to secure the pex tightly was to use emt straps and anchors. All in all, it was very labor intensive (two days) and no fun! I'm not sure I will try this again. -DF0 -
ACHOOO....
cough cough cough, snifff... I'm not sure I'd try that trick again myself, but how ya gonna know until you actually do it?? Right?
Good Job Dan. I'm sure they hired your company because they knew you'd get the job done, one way or tuther.
See you this weekend.
ME
I admire you
for taking on this retro. It's the type of job you will remember and talk about for years! Hope you were paid fairly
hot rod
What about
using Onix for this application, could have gotten away without using any straps?
J0 -
Onix
We considered Onix but the diameter of the hose is considerably bigger than the 3/8" pex which would have necessitated a wider, deeper groove in the concrete. No go. -DF0 -
Dan
That is one load of work...
My guys would kill me if I tryed that .
You deserve a big check and a cold beer,to wash out the cement dust. I'll be at the bar, whats would you like .
Scott
first off dan
thanx for sizing the pictures just right. unfortunately i am back on dial-up, so i don't look at too many pics anymore.
had similiar but different experience once. went to lay the loops for a slab on grade. the builder had poured the "first" lift of concrete we had to snap every loop line out first, then like you, had to attach to the concrete.
i feel your back pain brother!
looks like a top-knotcher again dan!
leo g0 -
challenge,
doesn,t suprise me a bit,coming from a man of your character and perservance.
its great to know their is a contractor in the dc area who is not afraid to take on a challenge. in my personal nobody opinion, whether you do it again or not is imaterial. This one is DONE.
respectfully,
pk.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
