pumping
Tim Morris
Member Posts: 1
1-Taco 007-2F5-5 pump is installed @ mix side of a sparco valve, pumping into a four loop manifold of 1200' of 1/2" Kitec. Experiencing low flow.
Do I need to add a pump?
Location?
1-Downflow from return manifold
2- supply side of mixing valve?
Location?
No cajones...
the 007 doesn't generate enough oompf to push water quickly through small bore pipe. Whats the longest loop and how many loops are there?
I'm guessing at a 0010 or 0011.
ME
4 X 300 ft?
Presuming a balanced load, as Mark says jump the pump. I'd stick in either another 007 close coupled or a single 0010. Push the fluids in the absence of design flow.... Dan
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
