Need a stand alone humidication system...........Casmo
I have some cust. who want humidity but not in the ductwork. Just looking for sources Thanks
Casmo
Dependable P.H.C. Inc.
Casmo
HUH ?
If you place any humidity anywhere in the house It'll get in the ductwork! Aprilaire has a nice stand alone unit that can be conceled in a closet or anywhere that there is about 2 cu. feet of space. Of coures a drain is needed. anyway bigugh0 -
good one
I understand, the problem is the customer has fiberglas ductboard, and I won't install a humidifier in the a/c system. Have seen too many mold colonies in older systems with fiberglas (did I mention that I think that stuff should be banned?). I was looking for options, thanks for the Aprilair info.
Casmo
Dependable P.H.C. Inc.0 -
After I sent
the above post, I got to thinking it sounded like I was after you and your knowledge of humidity. Sorry about that. Customers usually do not understand was what I ment. The next trick is are there any places where the duct may become cold enough for condensation to occur. A Stand alone humidifier still could allow mold in duct work at those sites. Hummmmmmmmmmmm... there are always kinks to be aware of! bigugh0 -
steam
if you do end up using the duct system to move the humidity through the house i would recommend a steam system. we have installed many of the ewc s2020 steam humidifiers. the have a flushing feature which will drain and refill the resevior. we have switched from the standard bypass and fan assist humidifiers to these steam units. customers really can feel the change in humidity with the steam as opposed to the bypass or fan assist.
jim f
milford, ct.0 -
darn those kinks
When I saw my first pex demonstration with the kinking and the heatgun I thought we had the answer for the kink.....
Casmo
Steam makes a lot of sense, what better way to atomize the water into easily transportable vapor. Are you listening Steamhead...you can do this you have finished getting all the deadman's systems working the way they should! How is the maintenance, will one maintenace per year be enough to replace nozzle, clean sediment from generator, etc?
Casmo
copied from web site
Computer Watchdog Circuit
Automatic Drain/Flush System
Highest Efficiency Rating than any other Humidifier
Automatic Maintenance Mode
100% Guaranteed NO Summer Maintenance
Interlocking wiring for Fan Control
Humidifies without a call for Heat
LED's for system readout
Most Effective Cure for Dry Homes
Listed and Approved by UL
Compatible with all Heating Systems
The Most technologically advanced Humidifier has become better with the help of a computer. The S2000 and S2020 Steam Humidifiers have a built-in computer chip to insure maximum efficiency, accuracy, reliability and safety.
The Automatic Flush system will drain the humidifier every (12) twelve hours of operation. This is a preventative maintenance mode to help protect the homeowner from a lack of efficiency. The humidifier will completely empty itself and not refill until another call for Humidity. This mode insures that all Summer long, when the humidifier is not in operation the unit will not be full of water.
The ONLY humidifier that will operate in the Heating system without a need for a heat call. The Steam Humidifier will operate and turn the Fan on independently of the Furnace. The Ultimate operation for Maximum homeowner comfort.
The LED read-out display on the front cover shows the proper operation of the unit. The display also shows the installer and homeowner the effectiveness and the reliability of the unit.
The UL label enforces EWC's commitment to product reliability and safety. Underwriters Laboratories (UL) is an independent auditing agency that rigorously tests the performance of electrical devices. Their seal is a symbol of Excellence.
The Steam humidifier will work on any heating system. The S2000 and S2020 are compatible with all makes and all models of Forced Air Heating Units. The Steam humidifier is the Only humidifier that will work to its fullest capacity on Heat Pump systems.
Specifications
S2000
S2020
Output Capacity 16 Gal./Day Output Capacity 22 Gal./Day
Square Footage 2,800 Sq. Ft. Square Footage 3,500 Sq. Ft.
Voltage 120 VAC Voltage 220 VAC
Electrical 1.4 KW, 15 amps Electrical 2.0 KW, 10 amps
Plenum Opening 6" X 6" Plenum Opening 6" X 6"
Weight 9 Lbs. Weight 9 Lbs.
Humidistat Included Humidistat Included
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
