mixing glycol
Bob Gagnon plumbing and heating
Member Posts: 1,373
can i add pink glycol to a solar heating system that already has yellow glycol. the customer drained 1 gal. or so. thanks, bob
Mixing Glycols
Hi Bob ! Long time no see. Nice to see fellow Canadians on the wall.
Re: glycols. You should not mix ethylene & propylene glycols. If the two are of the same type, it shouldn't be a problem.
You may want to test final solution to check if any additional inhibitors or additives are needed.
Regards,
Terry T
Frontier - Edmonton
Glycol blends
The engineers at Dow Heat Transfer Fluids division have told me mixing propylene and ethylene is not a problem IF they are inhibited the same.
For instance mixing hydronic inhibited with automotive would not be a good idea. The inhibitor packages that are added are completely different and not compatiable.
Can't really tell by the color what you have. Dowfrost propylene is a different color from Dowfrost HD even though they are both propylene glycols! Different brands are different colors also.
I don't know of any way to determine ethylene from propylene, in the field. Same with hydronic from RV from automotive. Need a lab to decipher the solution. Hope this helps.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
