1 1/2\" left hand thread nipples
Floyd
Member Posts: 429
figger'd out that the tapping on the one side is left hand thread....
Anyone know where I can get some of the nipples that are left hand by right hand thread????
Thanks!!!
Floyd
Thanks!!!
Floyd
try
http://www.plumbingsupply.com/leftright.html
never purchased from them, but they have them listed
Mark0 -
I've never met a plumbing supply house that didn't carry left and right nipples and couplings0 -
You must not....
go under the river much. I am in NJ and I didn't know what a "left & right" was til I started to work in NYC. If I went into any of my local supply houses they would look at me like I have two heads if I asked for one. I even worked in a suppy house before I started in the trade.
re: left right nipples
If i am correct, the reason one side is left hand thread is that it was part of a larger radiator at one time and a section has been removed. That was an intermmediate section at one time. R-L nipples we use all the time for gas pipe modifications as unions are not allowed. Never tried using a intermmediate end as the end of a radiator. ?? will be interested how it goes.0 -
nipples
Also try H.C. Oswald @ 212-722-7000. Good luck.0 -
left hand bushings
I needed one of these and couldnt locate any or anyone
who could point me in the right direction. So I had one of
my comercial customers make a box of brass 1 1/2" left by
3/4 right threaded hex head bushings many left over.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
