Spy Photos
Bob Tonner
Member Posts: 64
Partial List of Features:
1. Same size and mounting as Honeywell 8124
2. Flip open lid, with easy access for wiring
3. Lighted text display that shows:
a)Boiler Temperature
b)Burner Status
c)T-T status
d)X-X/ZR status
e)C1-C2 status
f)ZC status
g)DHW or Injection loop temperature
h)Remaining Warranty Period(counted down in weeks, only when control is energized.
4. Restricted access setup menu that allows installer to:
a) Digitally adjust High Limit (120-220 F)
b) Digitally adjust Low Limit (off, 100-180 F)
c) Digitally adjust Differential (10-60 F)
d) Select "Auto" Mode which adjusts high limit, low limit and differential based on heat loss profile on a continuous basis.
e) Select Pump configuration:
i) L-8124 (default configuration, just like you're used to)
ii) Injection (configures ZC as variable speed injection controller that maintains loop at temperature set by installer, with and sensor input
iii) i-DHW (configures ZC as dedicated indirect loop that maintains indirect DHW tank at temperature selected by installer, with sensor input.
iv) Priority (makes ZC priority pump and X-X priority input)
5. Completely Solid-state (no relays to fail)
6. Same price as an 8124
This is only a partial list of features.
Bob Tonner
President
InfinityLab Inc.
(905) 619-0837
b)Burner Status
c)T-T status
d)X-X/ZR status
e)C1-C2 status
f)ZC status
Bob Tonner
President
InfinityLab Inc.
(905) 619-0837
Spy Photos
New Boiler Control in final stages of development.
Operational details are yet to be announced, but we assure you that you will be impressed.
Bob Tonner,
President,
InfinityLab Inc.0 -
Will the
O-Scope be included? Don't leave us hanging to long.
hot rod
Hydronix Boiler Control
b)Burner Status
c)T-T status
d)X-X/ZR status
e)C1-C2 status
f)ZC status
ii) Injection (configures ZC as variable speed injection controller that maintains loop at temperature set by installer, with and sensor input)
iii) i-DHW (configures ZC as dedicated indirect loop that maintains indirect DHW tank at temperature selected by installer, with sensor input.)
Bob Tonner, President, InfinityLab Inc., (905) 619-08370 -
Send one my way
I'll give it the old contractors once over. I like being able to adjust the boiler on/ off diff. This would be handy for a large shop project I am going to run a 40 degree Delta t on the two staged boilers.
Did you say a post purge pump relay is in the brain also? Adjustable?
hot rod
Post purge Pump Relay
It is selectable in the menu-driven setup. I'll put you on the early prototype list for this winter.
Bob Tonner
President
InfinityLab Inc.0 -
Where are you located?
Are you in the Northeast USA? We are making a road trip soon and would be glad to show a live working model (of the control that is).
Bob Tonner
President
InfinityLab Inc.0 -
how about an approxamite price on such an item??0 -
Pricing
We cannot be specific at this time, but suffice it to say that you will NOT pay more than you are currently paying for a Honeywell 8124 or 7124. It will likely cost more than a 8148.
Best regards
Bob Tonner
President
InfinityLab Inc.0 -
Would love one for my training center
to use for training techs. If this is going to be used in the future on boilers I love to get in on the ground floor on new technology. I have actually been talking about the need for a control that does what your control is offering. Get in touch with me at:
Timmie M. McElwain
Gas Appliance Service Training and Consulting
22 Griffith Drive
Riverside, RI 02915
401-437-0557
FAX 401-270-18930 -
You are on the sample list
Timmie,
The first version available will be Oil Heat only. The Gas version will be hot on the tail of that one. But, for training purposes they have the same operational characteristics.
Bob Tonner
President
InfinityLab Inc.0
- 86.4K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 926 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
