Wirsbo Quicktrak
Vernon P. James
Member Posts: 42
Was playing with Wirsbo Radiant Express 4.71 and quicktrak and a window pops up for installation method of under or above subfloor. How do you install below subfloor? Is it installed on top of floor joist or installed under like a staple up? If installed under do you put plate up? I have never heard of Quicktrak installed under subfloor and don't see it in the installation manuals. Asked my dist and the Wirsbo rep and they never heard of it either.
Quick track
They go under the subfloor like staple-up, grove side down. I dont know why you would want to, aluminum plates are cheaper.We use Climate Panels(same thing) but always from above.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
