controls
BRIAN_3
Member Posts: 10
we are add a heating zone to a hot water system right now has two heating zones and a indirect h2o htr cold start all is good . 3 zones are controled with a taco sr503 multi zone control. x1 x2 got to tt on main control works great. now my problem is when adding 1 more zone without changing controls but adding a single control and have it start the burner when tt calls for heat any help would be great thanks
What kind
of boiler are you using?
Mark H
oil fired buderus with riello burner0 -
SR503 relay
Brian, check out www.taco-hvac.com. I think that control is expanable using taco relay , or maybe change it out with a six zone for any more upgrades0 -
if come from out put on single zone relay to zc zr on taco sr503 will that make x1/x2 close to tt and start burner0
- 120 Geothermal
