check valves
Performance
Member Posts: 1
I am looking for a check valve that works reliably in hot water heating- swing check, flo-check or those valves that come as part of Taco or Grundfoss pumps?
Different applications
require different types of check valves. Sizing is critical also, as oversizing may cause noisey operation.
What is the application you have in mind?
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
