new system
ed wallace
Member Posts: 1,613
a little help please i have a customer with oil fired warm air furnace needs replacing wants a bioler with indirect tank and a hydro air unit the problem is the location of hydro air he wants to put it in the unheated attic so my options are a lwco and or some kind of continios circulation im thinking of useing a plate heat exchanger in case the pipes supplying the hydro air freeze and burst
the reason for the bioler is in the future adding base board to some rooms that dont heat properly thanks
Ed
Why not use anti-freeze?If you didnt want to mix the whole system isolate the coil with a HX.
cheese0
- 86.4K THE MAIN WALL
- 53 Biomass
- 93 Chimneys & Flues
- 5.5K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 925 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15K Strictly Steam
- 41 Industry Classes
