An idea for chimney inspections
Wayco Wayne
Member Posts: 615
What if someone, (mayby me) designed a cage of sorts that would hold a video camera with a spot light that you could lower and take a movie of the descent of the camera. It would be even better if you could make it go up from the bottom, I hate crawling up on roofs. The real question is, does something like this already exist??
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Would a Drain camera work? nm
yes
one of the local chimney companies here in porland has a camera, and we have had him out on jobs to inspect chimneys prior to equipment replacement. i'm sure he does regular inspections as well. it's a cool tool, just a little eyeball on a flexible rod with some stabilizers to keep it centered. from the bottom he can go up 35 feet. so the last chimney i had done was 70' so we went in from top as well. wound up installing a liner because the chimney had some holes in it. Paul0 -
I have a Roto-vision camera that I use for duct cleaning and any thing else the little bugger will fit into. It has a 35' cord that connects to a color TV/VCR. Every week it finds a new use. Really like it for seeing what is inside if walls or crawl spaces that have limited access. It can be found at rotobrush.com0 -
Andy
How much does one of those run??? I looked at the web site but it gave no prices. Wayco Wayne
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
