Help! I need Square footage to ton of cooling formula
Ron Brandt
Member Posts: 2
I need to know this formula ASAP to bid a job. This is in a heat pump application.
Do I understand you are bidding an HVAC job based on a "check figure" rule of thumb? After you figure the load required, the material, labor and equipment costs, you might find this building works out anywhere from 250 SF/Tn to 500 SF/Tn. Good luck.
Bill0 -
Hi Ron,
I recomend that you not use the rule of thumb you are looking for. Especially if you are installing a heat pump. I believe if you use this concept in engineering, the job is going to come back to haunt you. I would further recomend that you contact...........ACCA.........on their website. Take a class on the manual J for residential heat/cool design. They are currently running courses around the country on their 8th edition of the manual J.
Dave Flood
Dir of Tech Ed
ICPA Tech Trng Ctr
Wallingford, Ct0 -
Thanks for your messages. I found the information on manual J and was able to calculate the square footage.0 -
\"HOOAHHHHHHHHH\"
WAY TO GO RON!!!!!!!!!!!!!!!!!!!0
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
