running pex through openings that need to be sealed
jim f
Member Posts: 182
anytime you make any penetration you should sleave the pipe. we also use the appropriate size pvc sleve. armaflex the pex and firecaulk. even though fire caulk is very expensive we use it on most of our sealing through any penitration
Are there any products that I should stay away from when trying to seal an opening that I am running pex pipe through? Such as silicone, thumb gum, fiberglas insulation. Will any of these ruin the integrity of the pipe?0 -
Our method
We sleeve the pex in a piece of reamed PVC of suitable diameter after wrapping the pex with a piece of Tyvek building wrap. Use a little masking tape to hold the Tyvek in place while you push it through. Leave a little of the Tyvek exposed and then caulk with whatever you want. The caulk is in contact with the Tyvek, not the pex. This also allows for friction free movement of the pex.0 -
Pex
We use a firecaulk wherever the tubing penetrates a wall partition.Most all of the rated firecaulks that I know of are combatable with pex.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
