Logamatic 2107/Zones
Doug Thompson
Member Posts: 1
I am installing a 2107 and want to control two heating zones with same water temperature. Circuit #1 is constant circulation with rads. and thermostatic heads. Zone #2 is an air handler controlled with wall stat. Do I need a zone relay such as the Taco SR502? If so, does the stat wire go to the relay and then on to the air handler?
Thanks for your help
Doug
Doug
Buderus has an Acrobat document available that covers a whole bunch of wiring options. Here's the link ...
http://www.buderus.net/bhs/PDF/Buderus Applications Manual Ecomatic and Logamatic Controls.pdf
You may have to type that in directly, or just go to their web site and click "Literature", then look for the HS2017 application note.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
