carlin interference
jon_6
Member Posts: 26
on customers tv set. replaced cad call relay.transformer 14000k with carlin equipment and pcs motor on hb smith boiler. just trying to find out if this has happened to anyone else .pressure reducing valve broke and flooded basement and boiler. thanks
interferance
try adding a ground wire that might0 -
Carlin buzz on tv
remove ignitor and scape off paint where both burner housing and ignitor plate meet to insure a good ground between the two0 -
Ignitor
Make sure the star washer is on the screw holding the ignitor to the base plated at the hole in the ignitor with the metal tab. If it is missing scrape the paint on the plate under the screw. I have seen this in the past. Remember too the ignitor is polarity specific .
Leo0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
