ASTM
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
We are working in a new jurisdiction this week and I asked the inspector if we could use PEX pipe for our primary piping. He said it was OK as long as it had the appropriate ASTM approvals. Got me to thinking: what are the correct approvals?
We are currently using two kinds of tubing; both have the same DIN approval - 4726, but they have different ASTM approvals. One has E-84 and the other one has F 876/877. Does anyone know the difference and which one is "correct"?
Best wishes,
Alan
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Best wishes,
Alan
F876 - pipe spec
F877 - system spec
Ask your pipe supplier for copies.0 -
F876-01e1 is "Standard Specification for Crosslinked Polyethylene (PEX) Tubing
F877-02 is "Standard Specification for Crosslinked Polyethylene (PEX) Plastic Hot- and Cold-Water Distribution Systems
E84-01 is "Standard Test Method for Surface Burning Characteristics of Building Materials"
The "-01" or "-02" means they were last updated in 2001 or 2002 respectively.
I'll try to get an electronic version of the standards and e-mail them to you, but so far I haven't been able to do that. It seems like the F876/877 specifications would be what they would be most concerned about, but that's just a guess.
Good Luck,
Larry Ticknor0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
